crazydoc
Master Baiter
I emailed the following to Midiman tech support several weeks ago:
"The Problem:I got an audio buddy mic preamp as a christmas gift. I got a large diaphragm condensor mic recently to use with it, and have been somewhat disappointed in its performance. I measured the phantom power voltage of the audio buddy with a vtvm (essentially no load on the circuit). Open circuit voltage is 35 volts, and voltage with one mic in the circuit is 27 volts. I haven't measured it with two mics, but suppose it to be even lower. Phantom power is supposed to be 48 volts. I believe I have a defective unit, and would like it repaired or replaced. Advise me how I can have this done. Thanks."
After a week of no respose to three posts, I called on the phone and after being shunted around a few times, spoke to someone who allowed that the voltage "seemed a little low." He told me I could send it to them and have it looked at and repaired.
I was reluctant to do this as it's my only preamp and I'd be unable to record while it was away (for an indefinite time period.) I took it back to GC where I had bought it, and even though this was now some 4+ months later, they agreed to replace it. I exchanged it for what appeared to be a new unit in a shrink wrapped box, but when I got home and opened it, it was obviously a return from someone else.
I tested the voltages of this unit, which were 40 volts open and 31 volts with a one mic load.
The audio buddy specs simply say "phantom power" and list no voltage or current values, so I'm probably SOL in insisting on 48+/-4 volts. My gut feeling is that it uses a low current voltage trippler or quadrupler which is poorly/cheaply designed and unable to provide the proper voltage in any of their units.
My burning question is this:
Does anyone know what type of signal degradation occurs as phantom voltage decreases, in a typical condensor mic circuit? If it's just a decrease in output voltage/volume I can live with that, but if it changes the mic's tone/frequency response that's another matter. Although the change could be for the better, in my experience random changes in life are always for the worse.
