B
Bare graves
hi guys this is my first post
i am pretty sure my points have been addressed howver there are hundreds of posts.
i am near the end of my music tech diploma but i find my tutors have not explained things well and spent 5 minutes only on mastering.. out of two years.
so here is my problem firstly when i was mixing the snare the hits where really peaking in logic yet they were still quiet which makes no sense to me.
also when you use a longer attack on a compresser say on the snare it means that it wont take effect for a few milli seconds right? surely that means the frist part of the hit is at its orginal level which means the level is not being controlled. its hard to explain but basically whats the point of the attack when trying to control the dynamic range as the frist bit of the hit gets through uncompressed?
can this also create a popping sound? when i mastered the tracks one of them has odd popping sounds when the snare hits. can anyone explain why?
the other tracks are ok because i used midi triggers for snare and bass drum.
most of the equipment i was using was broken and the signal path was noisey. but luckly the genre is Punx
track three is the one with the snare problem
www.myspace.com/visionsofgehenna
sorry about the essay
