I believe it was just introduced at NAMM. You can check it out here. http://www.audio-technica.com/prodpro/profiles/AT3060.html Not sure I like the frequency response curve. I doubt anyone would have one yet. Even though it solely runs off phantom power, it doesn’t appear to require any more current than their other mics. I don’t see how they do that – but hey, if it works, it works.
-Flatpicker
yea i', with Flatpicker on the responce...
everyone is making affordable tube mics these days..how much should this mic be?? less than the at4040? i have a friend that plans on buying a 4040 by the end of feb...
If anyone could sing above 10,000 cycles they should choose another mic, and jion the Circus, because you ought to be in a freak show. Nobody will accuse it of being too bright.
That's a little misleading. While no one sings fundamental pitches that high, there is plenty of information in that range from upper harmonic overtones, consonant transients, and breath. If you don't believe me, put a brickwall filter at 10k on some of your vocal tracks and see if you can't hear a lot of the life sucked out of them. Hell, even the SM57 will pick up stuff a lot higher than that.
