Seeker of Rock
Let us be unburdened by that which has been ?
This has been coming up on HC lately. I would use this to soften the overall highs where the signal is peaking my CDRW700 from tape. I will be using it on the entire mix but only to (hopefully) softly even out the signal. I don't consider coloration necessarily a bad thing, so that is not an issue. I just want to add a little compression to the output signal before going into my mastering deck (via the board and EQ). This will be used to record basic rock tunes, moderate rock drum hitting via a DM Pro kit and often strong, walking bass lines. Budget is $250 max., and both currently fall withing this range. Any suggestions of which one may better suit my needs or preferences/strong points/weak points of either? Anyone else used either or both?
