Are these legit bass traps?
  • Thread starter Thread starter Nismogolfer
It's foam. So I'd say the answer is "No". they're not legitimate bass traps. Foam is almost useless for acoustic purposes. It might help a bit if you need to tame some highs (though 99% of the time, highs aren't the problem in a room. The bass is the problem) But, for bass absorption, you need rigid fibreglass. So, using the words "bass trap" and "foam" in the same sentence is an oxy, moron. :)
Don't laugh Nasa uses water jets sprayed under the lift off to reduce the sound of lift offs.
:cool:
the shipping price tell you they weigh nothing bass traps require mass which unfortunatly is heavy, so an 8 pack shipped for $12 is very light.
$12 = £7 royal mail standard parcel = 4kg
bass traps are normally 25-50 kg per m3
build your own with rigid fibreglass works out alot cheaper
