are RCA cable and SPDIF cable the same?
  • Thread starter Thread starter Jotosuds
J
Jotosuds
are they the same cable? like can you use RCA cable for the SPDIF connection.
specifically for the V-amp2, cuz i'm thinking of trying the spdif on it, and the spdif IN on audiophile soundcard.
can you use RCA cable for SPDIF?
thank you.
no they are not...
SPDIF stands for Sony/Philips Digital Interface...
it allows digital information (sound) to be transferred from one device to another...without being converted to analog....
RCA is analog only....
I read on another website that if the rca cable is shielded well enough, then it would work in place of an SPDIF cable.
I have a J-Station and have been using the SPDIF out to my Audiophile and it seems to work fine. I'm using these gold plated rca cables from radio shack, though I think the cables are intended for hoking up to audio to a dvd or vcr. Anyway, if someone happens to know better please chime in let me know if this is all wrong.
The S/PDIF protocol specifies the use of a 75ohm shielded cable for best transmission of the digital signal -- this is different than the cable spec typically used for analog signals.
The proper impedance can be obtained from a relatively inexpensive video cable with RCA ends.
I got a HOSA S/PDIF cable with gold-plated ends for about the same price. Very reliable cable, unlike many of their analog products.
I made my SPDIF cables....
Radio Shack has 75ohm TV cable by the foot and non-solder (screw on) RCA ends that will fit.
I made two 6ft cables and it cost me about 10 or 12 bucks.
I never had any problems with them at all.
Fast.
Easy.
Cheap.
-mike
Good RCAs will work, even unshielded, especially on short runs, but not necessarily optimal sound quality. If you have to make do for a while you can use it, but you should get the 75ohm when you can.
I bought 2.5 meter prefab spdif cables for 4 euros a piece (like 8.5ft/$5). For that money, I'd say: Why bother trying to make them yourself?
