Blue Groove
who has used both? Any marked difference? I don't have access to the 3124+ and need your opinions.
Blue Groove said:But how does that affect the sound (compared to the original)?
Minion said:If you want to build your Own Opamps to use in your Preamp I have some schematics for a Class A/B Opamp that should work in any Unit that uses a standard 8 pin Opamp.....
Let me know and I"ll post the schematics.....
Cheers
Minion, have you ever used your opamps in API, John Hardy or other gear that uses 2520/990-style opamps? They're all 6 pin, BTW.Minion said:If you want to build your Own Opamps to use in your Preamp I have some schematics for a Class A/B Opamp that should work in any Unit that uses a standard 8 pin Opamp.....
Dot said:Minion, have you ever used your opamps in API, John Hardy or other gear that uses 2520/990-style opamps? They're all 6 pin, BTW.
FALKEN said:I would like to see this.
Minion said:Here is the schematic, I also have some other Documentation if you would like it but you would have to PM me with your e-mail so I can send it to you as it is a PDF File.....
Cheers
