PhilGood
Juice box hero
EdgeGuy said:I'm getting close to hammer time.
Last question(s) before I order my caps.
I will stay with 1uf - but if I go higher will the bass also increase? - or is it already maxed out?
Also: I have been told that I can lower the VDC with no ill effect. The cap installed is 450v when there is only about half needed. Where Im going with this is getting the smallest size while improving the sound the most.
Sound being #1- I will hammer it in if I must.
Thank you
Bobby
The cap just acts as a high-pass filter. You won't increase the bass response, but you will extend it. If it cuts off at 30hz you mught change it to 15hz by using a larger value cap.
The voltage rating is the capacitors MAXIMUM voltage. If its rated at 450v, that means it can't handle anything higher than that. I would go with a 250v. That's what I used in mine. I had to lay it flat nest to the tube socket and work the leads around other parts.
