PhilGood
Juice box hero
Gus, would you mind re-posting this info??
I don't mean to impose.
Gus said:Is that you Bobby S? If so the I lost your number and message on my machine because I replaced the phone. give me a call.
I have a better circuit for that microphone. People are missing a circuit I posted in the past. Also people are missing some problems with the power supply. Still have the mxl603?
Do you check "the Lab"
PhilGood said:The phase problems are only shown on the graph. Can't remember where that link is, but I'll find it.
If I would go for a higher value Ansar, it would be a 3.3uf 400v CPA, which is a lesser performance cap than the SPA, but about the same size. That would extend the bass a bit. Probably down to 20hz easily. Too bad we couldn't find a paper in oil that would fit! That would be the best!
Marik or Flatpicker or mshilarious could tell you how to alter the negative feedback, if it exists. I've always heard that negative feedback can actually correct renagade spikes. Wish Gus would comment! Haven't seen him here in a while.
Did you try a better coupler cap for C4? If we could find a suitable polystyrene, that would KILL and solve alot of problems. It would have to be a suitable voltage. I've used 1000pF 50v on SS mics and it makes a HUGE difference!
BTW, I am using Telefunken 12AT7 for the tube, and found it seems to be the best suited for the circuit. Tried a 6072A, but found it to be too soft sounding.
mayonaise33 said:I have this mic and am very new to microphones.. I think it is pretty decent out of the box..
It seems to work good on vocals and acoustic guitar, for me anyways..
Are these improvement you guys are talking about really make that much difference, and if so is it easy to "swap" tube or something that someone with absolutley no electrical experince, like myself can do?
PhilGood said:Swapping the tube is about the easiest thing to do in this mic. You just need small screw drivers and have to hold down a spring.
An NOS (new old stock) 12AT7 or 12AY7 will be a big improvement. GE, Mullard, Telefunken, something of that nature.
EdgeGuy said:Agreed!
Try one of these.
http://vacuumtubeaudio.com/item219.htm
Let us know what happens.
I like the mic stock as well but saw a lot of possibilities in upgrading some parts.
I already had a small stash of tubes to try and fell in love with the Telefunken 12ax7. The differance is huge. Note that this tube is 40 or 50 years old and isn't as hot as a modern 12ax7. A 12ay7/6072a (same tube) is better for the 460.
I think that when you hear your mic with a better tube you will be hooked on upgradeing your mic.
mayonaise33 said:wow 43$ is pretty steep for a tube, considering the mic itself cost 240$
I know this sound silly but what exactly will this tube do? Will it make the recordings more rich and full? Compared to the stock 460..
Also just to follow up, do you guys think the preamp does much for you? Like I said i am getting a firebox and wonder if the premap will improve the quality.
Thanks guys...
EdgeGuy said:Singers guitar is a Taylor 6xx. I always found his Taylor to be nice sounding but thin. Like most Taylors are.
I put up the 460 and was greeted to a massive sound.
I wanted to redo all the parts I had just done last week with matched earthworks! This single cheep POS beat out my earthworks and I didn't even position the sweet spot yet.
Ok - guitar done, now the voice.
It was so different than any mic I have ever used. Lots of color, alive and warm. Yet just not right. I have recorded this vocalist 50 times in different studios as well as my own using many different mics.
There are problems with this mic. A lack of dynamics or a compression when confronted with a loud signal. I might have to give up my Tele12ax7 for a nice 6072. I don't want to do that because I don't think the Tele is to blame.
I think the little transformer is to blame.
What do you guys think about that?
Was it a success?
Mostly.
I recorded the loud parts on there own track, used less compression on his voice and positioned the pop filter further from the mic. I also noticed that I was adding EQ (again like the last singer) at around 2 to 3k.
The mic got hammered today and the bass response never opened up any further. This cap (Anser 1uf 400v) may need more time.
I didn't want to change the transformer for something large and expensive. I might do it if I can find a trany that is capable and drops right in.
Anyone know what I should look for?
Its 2 AM and going to bed.
e-dog said:Has anyone actually tried that 3.3uf Ansar?
That's quite a value jump.. wonder if it might be excessive.
Mine (nady) currently has a 2.2 electrolytic "upgrade" in it, but I wouldn't mind trying something else.
PhilGood said:3.3uF is what is used in the Ela M 250/251 circuit. I did a homemade Elam with a 3.3uF, but later swapped for a 10uF mylar just to see what it would do.
I like it. I can always roll off the lows in the mix. I'd bet an Ansar would sound amazing.
Electrolytics sound grainy to me. Not very linear in their resonponses. They seem to lose a lot of detail.
