No problems to speak of with Sonar. Will it run in WaveLab as well , with no complications? The only reason I ask is because Wave Lab is VST , and Sonar is Direct X ? Thanks for your help Laptoppop !
Sorry ,but just to clarify. Can I use this card in Sonar , export the audio, and open the wav. in Wavelab and use the same plug-ins to master and not have any problems ? Also what is this process delay thing ?
I understood that in most plugs, the lag caused by the process is compensated, so the befor/after signals are still in similar sync, and with the UAD's you had to move them manually.(?)
Thanks
Wayne
