StratFreak
Greetings fellas
new here
great site
couple of questions if anybody can help me
sys specs
Cubase 32
XP 1800
512 DDR
7200 HD
Zoom
POD pro line -6
Korg key
Gina ( old 20 bit sound card w/ outbox)
Okay recording levels
on each track on the master panel is a db reading, one on top and one below each channel between the fader
I am able to set the value of the db on the bottom of the fader for each channel, should this value always be at 0? if not at what value?
Heres something odd, i can run my zoom through channel 1 & 2 pick a prgram beat, then i pull up the Gina controls and adjust the input levels and it differs to the input levels to cubase?, if the gina is set to 0 the input level to Cubase in channel 1 = -5 and channel 2 (stereo) is set at -4, should the Gina input db and the cubase input db be the same? or does it matter? or is this because the Gina is a 20 bit?
what is the best recording level i should record at? -5?
should i leave the bottom db value to 0?
One more, should all instrument be recorded at the same level? or is it better to set some recording levels on certain instruments different during recording then go back and adjust the volume for each channel as desired
can anyone help a Freak?
Thanks
new here
great site
sys specs
Cubase 32
XP 1800
512 DDR
7200 HD
Zoom
POD pro line -6
Korg key
Thanks
(and also a fellow Strat lover and Zoom 234 user)
