J
jonnyc
The two v30's I got are 8ohm speakers and the celestions in my 4x12 are 16ohm. It's a typical 1960a model with the stereo switch and 4ohm and 16ohm jacks. Is there anyway to wire this up so it'll work or no?
Zaphod B said:Never mind, I found a wiring diagram for a 1960A cab. Pretty cool, I didn't know they had all those options.
So, again, what are you trying to do?
Oh. Well, then, the quick answer would be no, not if you want to maintain exactly the same functionality.ggunn said:It sounds to me like he wants to swap out two of his 16 ohm speakers for 8 ohm ones in his 1960 cab.
Zaphod B said:Oh. Well, then, the quick answer would be no, not if you want to maintain exactly the same functionality.
First case: If you throw those 8-ohm speakers in there, both on one side, then in mono mode the 4-ohm jack becomes 2.66 ohms and the 16-ohm jack becomes 12 ohms. In stereo mode the impedance on the side with the new speakers would become 4 ohms rather than 8 (the other side would still be 8 ohms.)
Second case: If you put the new speakers in with one on the left side and one on the right, then in mono mode the 4-ohm jack becomes 2.65 ohms and the 16-ohm jack becomes 10.6 ohms. In stereo mode both sides would become 5.3 ohms rather than 8 ohms.
I've been told that most tube amps are very tolerant of impedances that are not right on the money, particularly if the speaker load is a bit higher than the rated output load from your amp. So in the first case, using the 16-ohm jack (which is now 12 ohms) with a corresponding 8-ohm output from the amp would be safe. In the second case, using the 16-ohm jack (which is now 10.6 ohms) with a corresponding 8-ohm output from the amp would also be safe, and even more closely matched.
Absolutely correct. You want to keep away from those low impedances.ggunn said:Yeah, but the 4 ohm mode at 2.65 ohms (and thanks for doing the math; I didn't have time to do it) would be a bit risky.
If it were me I'd put one on the left, and one on the right, and use your amp's 8-ohm output into the 16-ohm cabinet jack (which would now be 10.6 ohms) in mono mode.jonnyc said:So if I throw them both into the same side and run thru the 16 ohm jack I'll be ok? I just don't want to blow anything up.
Zaphod B said:If it were me I'd put one on the left, and one on the right, and use your amp's 8-ohm output into the 16-ohm cabinet jack (which would now be 10.6 ohms) in mono mode.
jonnyc said:Do you think this would be the safest bet? I just don't want to blow my head, I've lost one already and I don't want to lose another.
Micter said:Then don't mess with the speaker load. Although running the load higher often doesn't cause a problem that all depends on the output transformer. I personally don't mess with impedence.
