briank
analog for the people!
Went to take some measurements on the PLL and swap a couple ICs in the AT board but today the left reel has decided not to work in play/rec either...this "moving target" stuff is bugging me out. This machine is mocking me!!
So symptom sit-rep today:
With card in tape sensor slot, no tape loaded (since it will just dump on the floor):
-both reels idle fine; both can be trimmed to the correct 3 revs per second idle
-FF and REW: function fine--left reel spins in RW and right reel spins in FF; tape lifter function as they should
-PLAY and PLAY/REC: light up; the capstan spins fine but neither reel spins now (for the last couple weeks up until today it was only the right reel that didn't work in play; a few weeks ago both reel motors spun in play although tension was too low on right side)
-STOP: stops the capstan from play; slows and stops reels from FW/RW
-EDIT: lights up; stops both reels idling
PLL gain should be ok; showing 19.2k/9.6k/4.8k at 30/15/7.5ips; 5v/22v ok; tried checking the ICs and testpoint waveforms per the PLL troubleshooting section of the manual; voltages are correct with a card in the slot in play at 15ips but I can't load tape since the reels won't turn in play now.
In summary: yesterday the machine had a good hair day; today, not such a good hair day. This is agony!
