Hi all. So i just did the capacitor upgrade mod to a pair of 603s that I have. In the process, i tried to get some recordings so i could hear the difference in the upgrade.
Prior to now, i never did any testing to compare my 603 pair. i always assumed, same mic, must sound similar.
After modding one body, i did my first test and noticed an astonishing difference. I found it hard to believe the mod would make such a big difference. I then modded the other body and discovering that i wasn't hearing the difference from the mod, but rather differences between the two capsules.
Attached are two recordings so you can hear what i'm talking about. mic placement is about two drum sticks above the left edge of the snare drum pointing straight down. No processing done. I tried to match the gains as well as I could. I swapped the capsules back and forth a few times (between two modded bodies) and got repeatable sounds every time. I kept the bodies in place, and just swapped the capsules, so i don't think i'm hearing a difference due to the small change in position. One capsule is dark and sounds like it has a lower mid bump; the other is bright and brittle.
anyhow, just wondering if anybody out there has experienced the same thing with 603 capsules. maybe one of mine is defective? For those of you that own 603s, which one sounds more like yours?
Dark 603 Capsule
Bright 603 Capsule
Dark 603 Capsule
Bright 603 Capsule
