Any Akai GX266ers out there?
  • Thread starter Thread starter Stevebol
Stevebol
After being away from analog R-R for a few years I'm getting ready to get back into it.Any Akai users have some tips?
Hi Stevebol,
Yes, I have many of Akai's models here that I use.
Not exact the 266 model but probably 25 other models.
What do you want to know,
maintenance, problems or ?
Best regards
Vintage TX:cool:
I finally got my machine up and running in the last few days.I've had it for a while.One of the pots was scratchy so it took a while to take it apart and get some WD-40 on it,but it runs like a champ now(knock on wood).I don't want to get into doing much maintenance myself but what can I do that's simple?I never did anything to my previous deck which was a Fostex.
Hi again:)
The most important is to clean the travelpath and tension-arms. a The pinch-roller shaft every 6 months = unscrew the cover and pull out the pinchroller carefully, don't loose the small feltwasher behind the cover = clean the shaft and put one small drop of light machine-oil on the shaft. Use a Q-tip for the center-hole of the pinch-roller and re-assembly.
If the heads and and all guides were the tapes travels clean and smooth just enjoy it.
When or "if" you notice some problems or misbehaving, then take action.
Did you visit my website ?
There is many other Akai models and information if you are interested;)
You welcome, if you need any advice just contact me;)
