Slackmaster2K
Gone
1) It was mentioned to me that a power amplifier wants to work at full power, and that volume should be controlled before the power amp. Is this by explicit design? If the output quailty of an amplifier varies with amplification level, then is full volume the design target for optimum quality, or is it some physical property of amplification that makes this so?
2) Integrated amplifiers combine a preamp and a power amp. I have a cool old NAD 3020 integrated amplifier that allows me to bypass the preamp and tap right into the power stage. Is it likely that this would be beneficial?
3) If I run my signal into the auxillary input of the integrated amp's preamp, would I crank the volume up to max and control the volume before the amp, as I mentioned in #1? It seems to me that I wouldn't, and by doing so I'd just be adding an extra fader to the signal...and depending on the design of the preamp, I could certainly overload it.
4) Input to the amp is from a Delta44, a semi-average 24bit soundcard. Does anyone know specificly if the output volume control of the delta is digital or analog? If it is digital, then I should probably leave it at 100% right? If I leave it at 100%, and I wanted to run the signal directly to the power stage of my amp, I'd need some sort of fader. I was thinking about getting the (gasp) Mackie 1202VLZ because the mic pre's get Scott Dorsey's stamp of adequacy, and I could use the routing options. Or I could just leave the delta at 100% and run the signal into the aux channel of my amp's preamp, and control the volume there (e.g. #3 above). I'm not sure if this is the same question anymore
Slackmaster 2000
Slackmaster 2000
