The question on needs to ask himself is: "Is there really someone (or something) out there who's about to get me, that makes me worry about getting away ?"
Precisely. If you are going to mix on the same machine you track, all you care about is that you have a total system response (from input signal to output on tape) that you can use to do your music. It doesn't have to be flat and, unless you will play back on some other machine, it doesn't have to be set up with any interoperability standard in mind. OTOH, using those standards is often easier, since the cal tapes are available and it makes for a consistent and easily repeatable process.
I have a large compilation of data I have in a file. Not on this computer at the moment. I can PM you (I think) the file is about 14 MEGs though. I;ll look for the scotch pages and separate them out. Sorry, I hadn't noticed this thread had been updated or I'd responded sooner!
