C
Chris Burks
I bought a series of converters and cords to try to improve my recording situation. I use Audacity as recording software.
I'm using a 3.5mm (1/8th inch) cord to connect from my computer (input slot) to my amplifier through a 1/8th inch female to 1/4" male (line out slot). This by itself, with the amp on, causes a massive amount of static that does not go away no matter volume or amp settings. When using a microphone into the amp through an XLR to 1/4" converter, the hiss becomes louder and if the volume is turned to a substantial level, my speakers emit an unbearably loud squeal.
If i cut the PC out of the equation, using my mic in my amp produces a loud hiss as well.
The funny thing is, when I plug my guitar into my computer through my amp, it works. Though the same "massive amount of static" results from using the line of of the amp, my guitar at least records viably otherwise.
I also picked up a short 1/8" M to XLR F cord to plug my mic directly into my PC's sound card through the "mic slot" and my PC doesn't seem to acknowledge the mic's existence. Audacity doesn't pick up any sound being put in through the mic.
So, that's what is happening. I'm 18 and using a really basic set up, obviously. I don't know much on this subject. My question: Is there a few things I can do to cancel hiss and make my equipment usable? Or is this set-up simply not going to work? Thank you.
