harley96 said:
Considering most people are not going to use either one as a vocal mic and I normally get it in writing before I leave the store.
Great point!
I did the same thing. bought the beta52 had it at the house for a few weeks comparing it to a buddies D112, took back the 52 and switched it out for the D-6 (written came in handy)
BTW I'm doing Rock/Pop/Blues style, with a DW- Birch 22"x 18" kick. my thoughts on all three mics FWIW:
D112: has a clicky attack, a little bit finicky as for finding its sweet spot, did cut through the mix well, needed some EQ to bring out the low end. made my kick sound very close to the room sound...this mics tone hits you in the gut!
Beta52: very boomy had more than enough lows but had a bothersome mid range honk (which could be repaired with EQ later, also needed some work to stand out in mix) the toughest of the three to find sweet spot, placement was a bit challenging, was the most versitile of the 3 though (worked great on bass cabs and even guitar amps) however I was in desperate need of a go-to-kick mic...this mics tone hits you in the chest!
Audix D-6: had enough click to stand out in mix, very scooped across the mids making it basically fuss free as far as finding sweet spot and placement. sounded great right out of the box wherever I put it...a down side to me is that it sounds the same every where you put it due to its heavy scooped mids. on one hand it makes placement easy. on the other hand, if you want slightly different sounds by mic'ing front of head, or deep inside, or beater head, or at the sound whole, theres not much tonal change...this mics tone hits you in the balls!
truth be told, I now believe I could get any of the 3 to sound good by just EQ'ing later, its just the D-6 was by far the quickest, trouble free choice.
as always, IMO!...good luck
