M
Minim
Hi All
I am trying to get into home recording. A friend gave me his old lexicon alpha interface and I downloaded Reaper. I also downloaded the latest driver for the alpha and it's set to use the ASIO driver in reaper.
I have been able to record line inputs from guitar and keys ok but am having trouble recording vocals. I first tried with an SM58 that I use on gigs but the level was really low going straight into the mic input on the alpha. I could shout in the mic and it could barely be heard on playback. The waveform visible on the track I recorded was also tiny compared to the instruments I had recorded via the line input.
After a bit of googling, I got the impression that an SM58 isn't ideal for recording and the mic preamps in the alpha aren't great. I figured I'd need a condenser mic sooner rather than later and bought an Behringer B1. I also bought a phantom power supply as the alpha doesn't have one built in.
However, I still have the same problem when trying to record with this new mic in reaper - the vocals from the mic are barely audible on playback and the waveform is barely visible. Even with the input gain turned up to the point where the peak light on the interface is on and I can hear the sounds from the mic distorting in my headphones, the input level on the reaper track won't seem to go beyond about -36db.
Strangely enough, if I use an XLR-jack cable and plug the mic in via the line input instead of the XLR mic input, I actually get a lot more signal in the software - making me wonder if there's a fault with that input on the interface.
Having said that, I am a complete noob so it's perfectly possible that I'm doing something wrong. Any help or advice you guys can give me would be very gratefully received as it's driving me insane at the moment!
Thanks in advance.
Thanks in advance.
