Yonce N Mild
Voice of Sanity
I am starting the process of treating my room. I have moved the computer to the closet and positioned my desk so that I have sufficient space behind my monitors and my head is at the correct listening position of .38 along the long wall. I am building speaker stands that will allow me to spread my monitors out a bit to get the equilateral triangle thing going.
I am building 7ft tall 2ft wide 4 inch thick bass traps using roxul rockboard 60 in homemade wooden frames wrapped in burlap. These are for the back corners. The ceiling is about 7ft 6 inches so that will give me bass traps almost floor to celing in the back corners.
I have 12 sheets of the rockboard. It will take 7 sheets to make the bass traps. That will leave me with 5 (one of which will be in four 1 x 2 pieces)
So my question is what would be the best use of the other 5 sheets? My room is about 12 x 14.
I was thinking about using 2 for the wall/ceiling corner in the front and back of the room. Then another 2 for one panel each on the side walls. Then using the one that is cut into pieces for a cloud above my listening spot.
I also plan on buying a pack of auralex foam to clean up the high end reflections a bit but being in a almost square room this small I need a lot of broadband absorption/bass trapping.
I can't really place anything in the front corners because of the doors.
Any suggestions? Am I on the right track?
