W
Walter Tore
I am trying to iron out a transfer problem from my adat recorder to the computer. I did a live recording with the ADAT saturday night. It came out fine, but when the tape tranfers to the computer, I get clipping at the -10db setting on the soundcard, even though the tape never went into the red.
The delta 1010 soundcard has 2 inputs -10 and +4. At -10 songs clip, but sound rich and fat, while on +4 they don't clip, but are thin. I had to turn everything up to 10 on the samplitude mixer because the sound was so low at +4db. I did a take 2 on Linda's mother was a junkie, using the -10db setting. There are a couple of clicks of digital distortion. All the other songs from saturdays session 11-12-05, are at the +4db setting. What I don't get is why this is happening, because the adat didn't go into the red.
I used to use a delta 66 soundcard, and I never had this problem. Thanks in advance! Walter
equipment chain:
condensor mics - 5 - 3 Electro Harmonix pre amps, and 2 pre amps on an Alesis Mixing board - Alesis black face adat recorder- delta 1010 soundcard- samplitude classic 8.1 recording software
you can hear the 2 versions of Linda's mother was a junkie below.
http://www.soundclick.com/bands/pageartist.cfm?bandID=157137
equipment chain:
