M
mnicoletti
Which ADAT do you have? Any deck OTHER than the original black ADATs will be able to display the errors for you by pressing and holding SET LOCATE then pressing Track 3.
Find a section of tape that plays with little or no errors. Record 10 seconds, no audio needed. Go back and play that section and look at the errors again. If they have gone up, you have a Writing problem that may be dirty (write) heads and which would need a good cleaning.
You should do this since you MAY be writing errors to tape that you are getting away with for normal recording but are screwing up the formatting (which lays down the control track).
Do you have any edge damage on the tapes? This is where the control track writes....
Mike
Mike
