C
junplugged said:how much better is using an ADAT for converters to maybe a 1212 into a PC vs. maudio octane adat out to same?
rory said:I've never used either of those two units mentioned, so maybe someone else can help chime in? BUT, think about this:
Do you know many big studio records being released that used either a 1212 or an octane? Now think back to the 90s, how many big releases were done on ADAT? Quite a few if I remember correctly. Eh... for what its worth anyway.
robin watson said:You're more clued up than me on the R2R stuff, but here's my take on that suggestion:
1. It's being used to record rehearsals: probably similar recording time per tape in either format, right? Tape cost is much cheaper with Adat; that said, if he's throwing it all onto computer (?) I guess the same tape can be reused. But if you're archiving, then Adat (properly handled) seems like a better option somehow.
2. Cost: Since when has the bottom line for an Adat been $150? I've seen Blackfaces for $75 on numerous occasions. 8-tracks of reel to reel machine is going to be comparably priced and probably more so.
3. Expandability: An Adat system could be upped to 16 tracks - nice if rehearsals are going well and the drummer's getting pissed off with only 3 mics on his kit! You're stuck with 8 tracks in reel to reel format, since 16 track in that format is going to be way more expensive (see also #1 regarding this point).
4. Reliability: Sure, Adat isn't perfect, but neither is reel to reel, although I have to agree with you that the latter has the advantage of being solid analog format (no drop outs). But a well handled Adat tape won't have any dropouts.
5. Cool factor: Reel to reel all the way baby (^:
6. Portability: He's carting this thing back and forth between the studio and home. If the r2r machine doesn't weigh more than an Adat, see #4.
7. Convenience: Adat all the way, especially if they'll be handling multiple tapes both at home and in the rehearsal room.
8. From tape to computer. Adat lightpipe remains a solid standard. Don't think you'll find one of those on a fostex.
Beck, this is not a mud sling. I love reel to reel, it's cool, and sounds the business, but I'm just thinking that an otherwise obsolete format (adat) would actually have the advantage in this situation.
A whole new dynamic in cross-posting SonicSonicAlbert said:I buy my rack rails from dblittlea-w on eBay:
http://cgi.ebay.com/1-Pair-6-Space-...9QQihZ009QQcategoryZ23789QQrdZ1QQcmdZViewItem
The rack rails are fine and the seller is good too.
No quite as long as an 8"robin watson said:What's a 7" ?
Cyrokk said:I use mine primarily as a AD/DA converter to my soundcard. It also comes in handy for transferring comp'd tracks to and then from the ADAT in order to save disk space.
EddieRay said:I've re-used S-VHS tape with no problems. Good thing too because I hear several mfgrs will stop making S-VHS. I think ADATs days are numbered.![]()
xstatic said:First, the ADAT converters are pretty poor, second, why not get an external hard drive? ADAT's require real time transfers and if you are not doing a digital transfer, 2 more steps of nasty conversion. Then there is the cost of the tapes themselves. A hard drive, even a smaller one, would store a lot more data, no quality loss, and do it MUCH faster.
