F
Fire Dome
Leeking said:
Do they ship internationally. I was checking out their prices and they are dirt cheap!! I don't know how they do it.
Leeking said:
Fire Dome said:Do they ship internationally. I was checking out their prices and they are dirt cheap!! I don't know how they do it.
I hardly believe that. Personally, I think it boils down to plain ole snake oilSo this firm is either clueless about its product application or sloppy enough to allow it to be inaccurately described
How many people do you think buy it BECAUSE it is advertized as SOUND PROOFING? They know EXACTLY what they are doing. So do I.Considering the number of newbies that show up here asking about putting some foam on the walls so that they neighbors won't complain about their band practicing I would say quite a few.fitZ2 said:How many people do you think buy it BECAUSE it is advertized as SOUND PROOFING? They know EXACTLY what they are doing. So do I.
fitZ
Rod Gervais said:Awww........ you had to go and do it................ I really wish you hadn't.
Sorry sir......... but you are very misinformed.
Foam does not help with soundproofing....... in fact - you can't find a single tested sound isolation wall / floor / ceiling design that uses foam product as a part of the assembly.
Foam is a product used to assist in tuning a room after isolation is completed - but it has none of the qualities needed for sound isolation - which (by the way) are (in order of importance) mass mass and more MASS.
Sorry, you really should be more carefull how you present yourself......... when you are going to do it badly you should not be in the process of explaining to someone else how little they really know.
1st - Foam is not a soundproofing "technique" - it isn't even a soundproofing product.
2nd - Of course people are looking to totally soundproof a room - the fact that it is virtually impossible doesn't change that (ultimately).
Nope - he's just like you or anyone else here......... I only know what he says......... I do not have one damned clue what he means - which is why i went out of my way to ask him........
You see - soome people are just like you - they believe in fairy tales - magic beans and dragons....... sheesh - they even believe that foam is an isolation product (I know - whoda thunk) - so when they present me with multicolored pictures - I try to ask them questions to see what they really mean.
Now - see that - you can do it......... you actually made an intelligent statement - I'm proud of you - I knew deep down that you could do it eventually......... although "good" and "inexpensive" are probably mutually exclusive terms when it comes to these products.
Sincerely,
Rod
Rod Gervais said:They do it by not using the same products - with the same densities as the acoustic foams........
gvarko said:I just got some from foambymail last week and I am telling you that it is exactly the same as Auralex without a doubt..
d(-_-)b-Phones said:It is the same. I have seen held and used both.
gvarko said:I just got some from foambymail last week and I am telling you that it is exactly the same as Auralex without a doubt...
d(-_-)b-Phones said:So scientific yet you like music? strange. I guess you also like solid state amps, active pickups and poly neck guitars... man its the same. I have seen them both, if you want to break out a chemistry lab and break the 2 down and see if they both turn sulfate blue... well thats you, better price same quality, end of story.
Todzilla said:Back to the foam as soundproofing wars:
In 1977 I covered every surface of my basement studio with egg cartons. Imbued with the confidence that no one could ever know I was blaring bad progressive rock, I blared. My little sister whose bedroom was just above the studio, traded her flute for a trombone, as the only reasonable retaliation for the unabated chacophany from below.
egg-carton nonsense aside, absorption probably has some infinitesimal affect in reducing sound transmission (and that is only at the high-frequencies, which are never the problem freqs in neighbor offending), but only in an academic sense.
Kevin, I'm afraid you need to eat crow on this one, buddy. Rod is correct that mass and isolation are the keys to sound proofing, not absorption. I know this anecdotally from many attempts as a failed practitioner. My current studio is constructed of sand-filled cinder blocks with a stucco finish. It is a standalone building, some 50 feet from the main house and 100 from the neighbors. It's mass and physical isolation from these other structures underly its relatively good soundproofing. The OC703 and bass traps that i have employed on the walls do a great job of controlling the sound within, but nothing for soundproofing.
Read the F. Alton Everest books if you want to learn about the physics.
A little bit of ketchup helps the crow go down easier...
Todzilla said:Whatever you say, Kev, but you know it's never the high freqs that bug the viewer in the next room. It's the thumpin's.
Please don't move in next door to me until I'm finally deaf. (estimated time to deafness, 3.5 years)
KevinDrummer said:MY anecdotal experience and unscientific perception is that a heavy dose of blankets, foam, whatever you can get your hands on, probably contributes to maybe 10-30% in HF reduction in the next room, sliding downward in effectiveness as the frequency lowers. Yes, the person in the next room is going to always hear that annoying LF rumble unless the room is properly soundproofed, but they just *might* be able to hear the evening news guy on TV.
I think I made all this clear in my posts, that the products can have some usefulness in the *proofing* arena when a casual hobbyist doesn't want to put big bucks into a room rebuild.
B) wrong - if you don't think absorbtion is (or can be) a major part of soundproofing. I know the physics.
Rod Gervais said:By the way......... what in the world happened to those people who were telling us the FBM materials are EXACTLY the same are Auralex foam? Rod
