R
ricecrispies
Member
As part of the acoustic treatment of my very reverberant live-work space (brick walls and ceiling, concrete floor) I need to install some acoustic pinboards. I am well aware that I will also need plenty of bass traps to dampen the lower frequencies. But that is something I will need to deal with another day. I need pinboards much more urgently. And since I need to install pinboards anyway on a patch of wall where I might otherwise have installed dedicated acoustic treatment, I need to think about their acoustic properties.
The pinboards that have caught my attention are Legamaster Board-It. They are marketed as being an acoustic treatment. On the other hand, they are very expensive, and I can find no information (i.e. numbers) anywhere about their precise acoustic properties.
So my questions here are:
I should also add that, if I buy a sheet of something from the DIY store, it will need to be strong enough not to crack under the use that a pinboard normally gets even without a flat wall behind it to support it properly. This is because I live in an old factory with raw brick walls that are not at all flat.
- Is there anything special about Legamaster Board-It pinboards, acoustically speaking, or will any old pinboard (including perhaps just a sheet of something or other purchased from a DIY store) have a similar acoustic dampening effect?
- Is that acoustic dampening effect enough to make a significant difference in the frequency range for which it is intended?
- If there is indeed something special about Legamaster acoustic pinboards, are there cheaper alternatives available (I'm looking for stuff available in Europe, but if you have recommendations that may be useful for other people reading this thread in the future who may live elsewhere, they would be great too).
