antichef
pornk rock
On to the next issue
-- I've been running mixes through my ACMP-81s using the outs and ins on my audio interface. All was happy until one of them started motorboating
I messed around with it some -- it seems to be related to the total gain level across the system -- above a certain threshold, the oscillation starts. If it's oscillating, I can stop it with either the input gain or the output level, and then as I creep it back up (either one), it hits the threshold and the oscillation starts again. The EQ can make it worse if the EQ is acting to increase the gain a little, but other than that, doesn't seem related.
Here's an mp3
This time, the beats are much quicker, and it sounds more like a cylon than a motorboat - that changed when I opened it up. The sound you here is me turning up and down the input gain to incite, then squelch the oscillation. At the end, I have the EQ engaged, which changes the character and intensity of the zappiness, but that's it.
Aaarggh!!
All the transistors on the preamp board and the output board are BC184C - I went to see if these were sub-spec, and noticed a lot of people use them in Neve-like circuits.
edit: I should have mentioned - this is one of two units - both were functioning fine this morning. The oscillation happens with or without signal going through (made the MP3 when there was no signal). This is happening on the "line" setting. On the mic setting, it also happened, but I had to turn both the input and output all the way up -- there was no mic cable attached.
Anyone got any ideas?
Here's an mp3
Aaarggh!!
All the transistors on the preamp board and the output board are BC184C - I went to see if these were sub-spec, and noticed a lot of people use them in Neve-like circuits. edit: I should have mentioned - this is one of two units - both were functioning fine this morning. The oscillation happens with or without signal going through (made the MP3 when there was no signal). This is happening on the "line" setting. On the mic setting, it also happened, but I had to turn both the input and output all the way up -- there was no mic cable attached.
