dgatwood
is out. Leave a message.
Tonight, I started to disassemble my pair of 6802T mics in preparation for doing a capsule swap. Unfortunately, I found out about Chinese manufacturing quality and consistency firsthand tonight. Out of the six screws, I was able to remove three (two in one mic, one in the other) without drilling, and was able to get one more out with a torx driver after partially drilling. Of those four, I was able to get two (the two that came out most easily) to screw back into the mics without binding.
After drilling the heads, the beheaded screws came easily out of the threaded part with pliers, so apparently they were binding with the unthreaded part. That suggests to me that the manufacturer didn't drill the holes in the body big enough, but it is also possible that the holes in the screen were mistapped at a slant. Hard to say which. What's odd, though, is that some screws bind in holes where other screws don't. I'm utterly baffled.
So now I have two mics, neither of which can be reassembled without new screws, and they're a size that is pretty much impossible to purchase locally. My calipers shows them being about 1/16th of an inch in diameter, or about 1.5 mm. Not sure exactly.
Any advice short of drilling larger holes and tapping them for a size that's more readily available (e.g. the size of hard drive mounting screws)?
Oh, and I broke my 1/16th inch drill bit on the last screw because of the steep angle I had to drill at. I'll have to stop at Lowe's on the way to work tomorrow and buy a new bit.
Looks like it's going to be that kind of a week....
