a few questions from a newbie
  • Thread starter Thread starter crispjaysalways
C
crispjaysalways
I want to set up a drum machine and keyboard and maybe an adat machine up to my computer. I have a regular ol' Dell desktop. What do I need to do as far as memory and soundcard?
When I get them hooked up and making noise through the speakers how do I make beats with them? I mean what is a good program to use for all of this, there are so many choices.
I have alesis studio monitors with a power amp, how would I hook them up to get the sound from my computer? My goal is to be able to make beats and have them displayed onto my computer. I want a nice little hobby studio, but have absolutely no idea where to start. thanks!!
What's the current spec of your computer?
What's your budget?
How many sources do you need to be able to record simultaneously?
I record live instruments so I don't know too much about sampling and making beats and stuff, fruity loops has a good rep in this area though. Get over to the DJ/Hiphop/Rap/beats forum and see what those guys are using.
To get sound out of your computer you'll need to go from the line outs of your soundcard/interface to the ins on your power amp, the type of interface you need depends on the answers to the above questions.
I don't think you'll need an ADAT machine as you'll be recording music onto your hard drive from where you can burn CD's, convert to mp3 for uploading to the web etc.
1. I have Creative Live SB soundcard. Pentium 4 cpu, 2.4GHz 256 MB of RAM. Is that enough? What is?
2. About a thousand, but I dont want to spend it all. What are my options for interface? BTW...Interface=sound card, right?
3. I will probably need to record 2 sources at a time at the most, correct? Im thinking, lay the beat with the drum machine, save it, switch to the keyboard, lay some stuff, save it, then maybe hook up a guitar or bass, and lay and save some more. So I would REALLY only need to record one source at a time, yes?
4. When would the need for more sources at once come into play? If I were to record a LIVE band?
5. Also I have a 24 input mackie board, could this be used for anything I need right now, as far as multiple sources being recorded at once, or does that depend on the interface? In theory, could I hook the stereo outs of the board to the stereo inputs on the sound card, and record everything coming from the board onto the computer on one track? Basically, 24 instruments on one track?
6. I need a great book on all this stuff. Any suggestions?
7. Thank you for all of your patience and help!! I look forward to getting this started, and I couldnt without people like you! Thankyouthankyouthankyou!!
1. That's a bit weak for a DAW, 512meg of RAM is really the minimum, particularly if you're going to be using software synths and stuff. Memory isn't too pricey these days, if you could stretch to a gig of RAM (and your MOBO has the slots) that'd be ideal. The P4 CPU should be up to the job though. Soundblasters aren't very highly regarded for recording but if you're looking at buying a 'proper' card or interface you'll be able to ditch it.
2. Yeah a soundcard and an interface are slightly different but they do the same job. Interfaces usually refer to external boxes which you plug your sources into and connect to the comp via firewire or USB 2.0 (USB 1.0 really isn't up to recording). Often these have other features like mic preamps and even control surfaces (like a mixer that integrates with the software). A soundcard is usually a PCI card which you install inside your comp, sometimes these have a breakout box though so are kind of like a soundcard and interface combined.
3. yep sounds like one at at a time would be fine for you but most interfaces have a minimum of two ins anyway. Good news because more ins means more $$$$$$$$. You can get a pretty decent 2 in card for not much money at all. Check out the M Audio audiophile 2496 for a dirt cheap 2 in 2 out PCI card with MIDI in out too.
4. yeah exactly, or a drumkit or something
5. Yes you could do that. If you have a multi input card and a mixer with direct outs on each channel then you could get seperate tracks recorded into the comp. But as you say if you've only got a 2 in card then you'd have a stereo mix of whatever goes through the board. In the absence of direct outs you can use track inserts as outputs by clicking a 1/4" TRS jack lead just half way in. A cool little trick as most cheaper mixers don't have direct outs but most have inserts. You could use the mixer for mic preamps anyway, they won't be anything special but they'll get you started.
6. Try a search here, I recall there have been a few threads like this and quite a few reccomendations made on books. Here's one such thread from a titles only search for 'books':
https://homerecording.com/bbs/showthread.php?t=203825&highlight=Books
On that note get used to the search facility, there's loads of great info on this site.
7. I've recieved a lot of help here myself so it's nice to be able to help others in return.
well your keyboard could be str8 MIDI using it's own lil track. and you'll definently need more ram I would say. and on your #5 on your list, your right. I got my 12 channel mixer into my audiophile and can record only recored 12 instruments into 1 channel. As for interface, with $1,000 you can get a 828mkII and save some of that money & get some ram, 2gb can run you around $129
B
Replies
1
Views
460
bainmack
bainmack
C
Replies
23
Views
3K
Old Music Guy
Old Music Guy
