NO! Cab's are typically connected in parallel when you daisy-chain several cab's. Plugging into 2 4-ohm cab's would show your amp a load of 2 ohms. That will be very bad for you amp, it's suck waaay to much current and probably fry your amp.
What you need to do is get those 2 4-ohm cab's wired up in SERIES. 2 4-ohm cab's in series would be 8 ohms.
OR probably easier - re-wire the speakers in each cab so each cab is 16 ohms instead. A 4-ohm 8x10 is probably all 8-ohm speakers wired as 4 sets of (2 speakers in parallel to 4 ohms). Those 4 2-speaker sets are wired series/parallel to grand total 4-ohm load. What you need to do is wire those 4 2-speaker sets in series to produce a 16-ohm cab. THEN you can daisy chain the 2 cabs in parallel to achieve the 8-ohm load load your amp wants.
