Marik
Pro Microphone Design
Finally, the transformer showed up and over weekend I had a chance to install it.
Here are some pics:
Enlarging the "window" for the transformer:
http://home.comcast.net/~markfuksman/6802Cutting Window.JPG
That's how PCB looks after cutting. To make the transformer fit the R5 is installed on the other side of the board. The C5 is a tight fit, you might need to pull it little bit out to be able to bend away from the lamination.
C2 and C3 removed for good. R4 replaced with 830K to lower the voltage on capsule to required 60V:
http://home.comcast.net/~markfuksman/6802ModedPCB.JPG
The trafo is installed. You can see I use a free hole of C2 for one of the leads. On the other side it is soldered to a nice capacitor:
http://home.comcast.net/~markfuksman/6802TrafoInstalled.JPG
The tube is rotated to minimize the length of the signal wire. Pay attention how nicely the Wima fits that space in the base holder:
http://home.comcast.net/~markfuksman/6802TubeInstalled.JPG
Stay tuned for more.
Here are some pics:
) and then post it here.
