Blue Jinn
Rider of the ARPocalypse
Hello,
Posted this on the Tascam forum too. Somewhat new to this as far as the technical aspects go. Have a couple of Dolby units to use with a mastering deck. (Expecting a Tascam 42 for that, currently an A-3300SX.) And yes the older Dolby units are pin 3 'hot'.
The Dolby manual says to calibrate use either the NAB or the DIN level on the dolby meter, the NAB corresponding to 185 nWb/m (0dB) or DIN 320 nWb/m (+5dB). My tape of choice is Quantegy/Ampex 456 (370 -- +6) and will bias new deck for that. So what if anything does this mean? Do I just go through the calibration and make sure 0 = 0 all around? Use the DIN scale and assume it is OK, use the DIN scale (+5) on the dolby unit and compensate with -1dB on the deck. (So that 0 dolby = -1 on the deck) Or should I bias the deck at 320 nWb/m (+5db) or what? And if I bias at 320 can I still use 456? (Seems to be so if I can use 406 on the same deck...)
I admit, I still don't quite get what it means that e.g. 406 and 456 are "bias compatible" but that 456 is "hotter" (I am assuming that means I can peak to +6 on the VU without distortion while using 456, but don't have the same headroom using 406.)
Any insight much appreciated.
