Farview
You run into the same problem with pro tools. you can only run half the plus at twice the sample rate. You are right, it doesn't bog down the computer, but there is only so much DSP to go around.therage! said:And there's another good reason to go with Pro Tools. Not that I'm advocating Pro Tools at all but if your going to doing a lot of plugs that off CPU and on DSP horsepower would only help a lot.
But to get what you need is a cubase setup and a second computer running system link with all your plugs.
