388 effects return question?
  • Thread starter Thread starter warcloud3
W
warcloud3
hey guys,
I've looked all over the board for the answer to this question and the owners manual isnt very discriptive on this point.
My question is: how do i get the effects from the mixer into my recordings.
I used the 1/4" effects send out and used the 1/4" effects return 1 and 2 for stereo. All the gains are turned up, Master, channel, gains and pans. I hear the effects (reverb and echo) just fine in the mixer and thru the headphones, but when i record the playback is dry. so the effects arent making it into the recorder.
Am i missing something, maybe a switch or something im not aware of, or do i need to patch the effects a different way.
Man, any help would be great,,,,, thanks
effects
hey,
as you're doing it now you're keeping your tape dry (which can be beneficial later i you don;t like the effect application). if you were to mix down from your deck the effects would be on the mixed down copy .. also i think you can turn on your pre/post button to get the effect on the trk if you want it to tape. I generally don;t put effects to tape..only add them in the mixdown process.
good luck,
pj.
thanks pjpjpj,
I do apprieciate your input, it is better to add effects later, i just dont have enough effects units to do what i want. Like a little reverb on drums and delay on vocals and maybe somethin on somethin on somethin on somethin. hehe
thanks
