You first have to Set the OUT point at the position where you want the pre-mastered material (your song) to stop. Fast forward to the end of your song then press the shift key and the end key (in your transport control area).
Next go to to your Audio CD Menu. On the AUDIO CD menu, move the cursor to PRE MASTER and press ENTER. The screen changes to the home screen, but with the word MASTERING at the top left of the screen. Check page 59 of the manual for more information. At the final mastering stage, it is possible to add equalization and dynamics through the stereo bus.
EQ
Like the ordinary channels, the stereo bus has three band equalization, with sweep able center frequencies, and variable Q for the midrange.
To access this:
1 Press the STEREO key.
2 Press the EQ key:
3 Use the cursor keys and wheel to select and
adjust the EQ parameters for the stereo bus.
Stereo Dynamics Processor
The stereo bus has a stereo dynamics processor (compressor or expander) available.
1 Press and hold the SHIFT key.
2 Press the STEREO key.
3 Use the cursor keys and wheel to select and adjust the parameters for the effect. Note that the last parameter is an on/off switch. When set to OFF,
the dynamics processor is bypassed.
Dynamics Library
From the screen, pressing ENTER brings up the stereo dynamics library screen.
Use the left and right keys to select the PRESET or USER libraries, or to SAVE the current setting.Use the wheel to select library entries and press ENTER to load the entry.If you save a setting, you can add a title to the current stereo dynamics settings and press ENTER to save it as a user library effect.
Remember recording is the easy part Mastering is a art.
Good Luck
