2 mic's into 1 channel
  • Thread starter Thread starter 2db
2db
Abbeyville Road Studios
sc100i-Combine two signals into one XLR feed
http://www.rapco.com/catalog2/deviceBoxes.aspx
Audio Technica AT8681
combines the output from two microphones into one channel. The balance control attenuates each microphone by 6 dB (typical) at midpoint.
Would like to use this instead of carrying a mixer to the field. Wanted to combine two drum mic's because I am working with limited channels on my deck. Any reason not to use a combiner?
C12VR and Beyer 201 together
http://www.directproaudio.com/images/products/at8681.jpg
shoudln't really be a problem, however I'd check how each unit handles phantom power, otherwise you may not be able to use phatom mics, unles you by a seperate phantom power unit for each mic...
It's just a matter of terminology. The "combiner" *is* a mixer. It's just a wussy little 2X1 mixer without very much gain. A small mixer would offer you much greater routing capabilities, be vastly more versatile, and not cost that much more, if any. The only reason to use a unit like that over a small mixer is if it *has* to be really, really, small.-Richie
