thajeremy
registered abuser
over the weekend, I tried to connect my second delta 1010 to my system. I installed the card, it was recognized and the drivers were installed. I connected the breakout box and everything powered up fine. When I started a session in Adobe Audition, I went to my inputs preferances and saw all my inputs....for both cards. I moved over the new inputs from the unused to the used side. then I set up my outputs. at this point, when I went back to my inputs, the ones that I had moved to the right side to be used were back on the left side....the unused side....so I moved them again. They would remain on this side until I viewed the outputs again...I could do anything in the program and the inputs would stay on the right side, but if I adjusted the outputs, the inputs would go back to the left side....
Also, I was able to get a signal from both cards but the software would crash, OR one card would continue to record while the other card would stop after 15 or 20 seconds.
I know this may be unclear but you may understand if you have had similar problems....
any advise???
thanks
any advise???
thanks
