NeveSSL
Hi all!
Just had a great idea for when I finally get out off college and get a job.
I'm thinking about getting an M-Audio Lightbridge and feeding with an Apogee AD-16 (the discontinued one... about $1500 used on eBay) feeding ProTools M-Powered. Using S/MUX on between the Lightbridge and AD-16 you can have 16 simultaneous inputs at 24-bit, 96k.
The only immediate downside is that the Lightbridge only has two outputs on it. While tracking, you would have to use these two for cues (IE, no dedicated control room mix). Or you could just get a DigimaxFS for 4 stereo cues and save the Lightbridge outs for yourself.
I thought about a Behringer, but they won't do 96k, so that wouldn't work unless you're doing 44.1k or 48k obviously.
In my opinion, two of the most important things in your chain is your preamp and your conversion. That would definitely take care of conversion and for pres I'll probably get an SCA chassis with two C84s to begin with and add some others as time and my hopefully "growing selection of mics" allow.
Just thought I'd point this out. I think this would make for a great basis for a great home studio. Everything in your chain matters, but to me conversion, mic pres, and mics (in that order) are three of the most important, and this combo would be freakin' sweet and would work with just about any DAW.
Also, one last thing. This is assuming you're wanting to mix in the box. If you're wanting to mix out of the box, you'll be much better off doing 48k outputs so you can have more outs at once (32 instead of 16) to feed back through your mixing tool of choice. BUT, I figure if you're doing that, you'll have an HD system anyway. Thats my ultimate goal personally (to mix outside the box, that is).
Any thoughts?
Brandon
I thought about a Behringer, but they won't do 96k, so that wouldn't work unless you're doing 44.1k or 48k obviously.In my opinion, two of the most important things in your chain is your preamp and your conversion. That would definitely take care of conversion and for pres I'll probably get an SCA chassis with two C84s to begin with and add some others as time and my hopefully "growing selection of mics" allow.
Any thoughts?
Brandon
