Jack Russell
I smell home cookin!
Some say the 16-bit version is good enough for most music; others say 24-bit is the way to go.
What do you think?
What do you think?
That's an excellent visual..........!cordura21 said:Hey Jack. Take a look at the pictures at this site, below the 4th paragraph:
http://fla.esf.edu/research/CAVLab/reference/candbd.htm
I find that the visual analogy makes sense to understand the basics of bit depth.
Andrés
Andrés
Jack Russell said:Thanks for the color link. I actually know more about photography and image resolution than I do audio. hahaha. Such as using 4x5 inch negs over 35-mm ones.
Not sure you are making your point more solid or less, though. If you look at the 8-bit and 24-bit unenlarged images, to the human eye they are identical (at least on my comp screen they are!). Sure, the magnified views show more detail in the 24-bit image, but that isn't what you will see with an unmagnified view.
The resolution gain in the 24-bit image is lost anyway in that it is out of focus just enough to loss clarity.
So, the question returns to the basic answer "More bits are better because they give you more detail." But can you hear the difference?
[At this point, I'll need to search for BBS's long version of his explanation for 24 over 16....;-)]
Sorry couldn't resist.
