W
WIZDUM
How do y'all feel about 1 compressor Bussed to all of the Vocal tracks in a mix (No Instruments)? Is it better to put an individual compressor on each vocal track's insert or does it matter at all?
WIZDUM said:How do y'all feel about 1 compressor Bussed to all of the Vocal tracks in a mix (No Instruments)? Is it better to put an individual compressor on each vocal track's insert or does it matter at all?
Ford Van said:Two different things altogether. Each has a place in production.
WIZDUM said:Thanks fellaz...guess I'll just try both...and whatever sounds best to me...
Ford Van said:That was more or less what I was getting at.
i use a group compressor on vocals if i'm doing say an "ooo" part or "ahhh" part, where there might be three tracks yet they should sound as one.xstatic said:I would try that next time BEFORE you comp any individual vocals. You might be surprised at how cool it can be. Mostly though it will give you a good exaggerated feel for the difference between channel and buss compression and how it affects your final sound. This way you may have a better idea of how or when to use it to your maximum advantage![]()
