Please give feedback on another track
  • Thread starter Thread starter David W. Pontius
David W. Pontius
David W. Pontius
Member
Howdy,
I found another track on that Cambridge website and spent about one and a half hours mixing it. I think I got things to sit pretty good in the mix, but would appreciate another set of ears. Beware it is 8 minutes long, so set some time aside.
Thanks.
Edit: I redid the compression chain on the master, adjusted some levels, and re-did some vocal effects. Everything should sound better now, please listen if you have a chance.
I listened all the way, before reading your post. You only mixed it.
I have stuff like this on DVD from Waken. It can make a good show.
The drums: They are either a very able drummer, or programmed. I'd guess programmed.
The girl singers: A bit loud and in your face (and dry) over the quieter music.
There's loads of words in it, but I have no clue what it is about.
The electric guitar: You get that falling note sequence in the first section. I get the feeling it is the same snippet pasted over and over.
That male singer near the end: Not my thing, but I've seen other chaps make a better job of throttling their voices like that.
I'm afraid this one sounded like he was sitting comfortably in front of a DAW, and not doing it convincingly.
As for the mix, you're starting with questionable material that you have no control over.
I listened on my new headphones (Sennheiser HD 280 Pro), which other tracks sound good on.
This one sounded a bit muffled.
But hey, I stuck it for 8:32.
The vocal really startled me. I can reduce the volume to where all I can hear is the vocal.
So ya it's really loud. Pitchy too.
The music sounds fine although it's like not homogenous with the female vocal. The monster vocal sits better.
Howdy,
Thanks.
Vocals are too loud - pitchy - and generally not good - guitar playing is really good but generic - drums are weak.
I think the drums are real because the peaks of the kick track are not artificially perfect. (At least the kick track is real imo).
The only gear I had to work with was a ThinkPad Laptop, a Vocaster One audio interface, and some Beyerdynamic DT 770 headphones. I no longer have studio monitors.
Like I said in my post, I was just trying to mix some track outs I got from a Cambridge website.
I can't tell if I added too much compression on the master, I think I might have distorted the kick a bit? Not sure, just trying to reign in the levels.
Please give it another listen if you have the time.
I tried to balance the vocals better with this latest version. Please listen to it if you have a minute.
(I also noticed the guitar player and drummer are very skilled).
I did listen all the way again.
There is a lot of competency in the playing, and the girl has a nice voice.
Yes, the drums do sound real.
Looks like they are a decent band, and I would probably enjoy the live show.
The mixing doesn't upset me. I don't know enough to pick tiny holes in it.
Guitars need to louder - Vocals need to brought down - and yes both the drumer and guitar player exhibit skill -it’s just not very interesting to me.
Thanks for the response.
