E
ejb
I am failing to get a decent recording of an acoustic 12 string guitar with passive pickup. I cannot use a mic. I cannot plug it directly to the audio interface, I cannot use main out signal. It is a live performance recording and channel insert (one click) is the only signal I have to feed the audio interface. So far it is a disaster. The fine sounding guitar is not coming through to the recording but does sound very good over the sound system.
Can you suggest a preset EQ/Effects or anything in GarageBand modeling that can take such a pitiful signal and get good sound out of it? Post recording EQ/effects applied are not getting it, or I have not found a good combination. I understand junk in and junk out, but experimenting with other instruments I have found near miracle plugins that make them sound really good, but I can't find such for this high-end 12 string...with passive pickup. I suspect the signal is too weak for processing? Maybe add a preamp?
It is plugged to a channel with a Hi-Z boost button on, yet I'm getting this thin, boxy, hollow, nasty playback yet it sounds great over the PA. Does Hi-Z boost, affect the output power of the insert one click method?
