mjbphotos
Moderator
This one sounds best:
34-49sec - Raw acoustic processed to the rules of the game (I made 4 EQ moves by mistake @ -4db each, not 3. That was just a mistake. Used compression and reverb)
This one sounds worse, it's lost all it's high end detail:
12-26sec - Processed acoustic that was used in my mix
Note that the comments above are based on these tracks by themselves. In a mix, things can totally change as you balance everything out.
Those are Yamaha HS8 monitors you are using? Have you done anything with the rear panel settings on them?
