Gtoboy
^^^ Check the local used market for on of the all in one type of channel strips with built in compression and eq then you will have all the basic outboard on one device. Then you can add to that later if you like.
Other than the tape noise issue, there was also the issue of only having a finite number of compressors to use during mixdown. You had to plan what you were going to use on what ahead of time.I wonder how much of the "compression going in" is a holdover from the days when you wanted a hot signal going onto tape to minimize noise. If you run compression afterwards, you risk bringing up the tape noise relative to the signal, so it makes more sense to compress first. Heck that's what the DBX system was, with a compression/expansion process, just to drive down tape noise.
I think Beagle hit it on the head. He does it in the digital domain because that's the way he works in the analog domain. As he said, that's the way it was done in the past.
It could also be, though, that you have a nice outboard compressor you want to use but don't have an interface with extra outputs available for sends/inserts at mixdown.Other than the tape noise issue, there was also the issue of only having a finite number of compressors to use during mixdown. You had to plan what you were going to use on what ahead of time.
In a time of virtually limitless plugin instances and nearly nonexistent noise floors, compressing on the way in for level control is pointless. The only reason to compress on the way in is for the sound of the compression.
I was speaking to the historic reasons why you would use it on the way in.It could also be, though, that you have a nice outboard compressor you want to use but don't have an interface with extra outputs available for sends/inserts at mixdown.
Oh, sorry. I guess I misunderstood your point on this then:I was speaking to the historic reasons why you would use it on the way in.
The CloudLifter needs phantom power to operate, and it's a fixed amount of gain. You really need to get the signal up to an appropriate level for the compressor to work properly.I've ordered a CloudLifter because my RE20 doesn't get enough gain with the 2i2. Would that be something that could feed a compressor? Then taking the compressor output into the 2i2?
The funny thing about recording bass amps is the fact that the mic itself becomes a "limiting compressor" along with the amp itself. I find I compress DI bass most of the time and amped bass rarely.I compress on the way in. Every time. BUT.....I don't compress as a fix for something I can't control with simple mic technique /placement and preamp level control. I use compressors for the value their individual circuit adds to the sound of the take.
A vocal will always get a fast comp first and set to control ANY plosives...the second comp will be the glue and the intimacy of being able to 'work' the mic.
Is this "old School" ? I certainly hope so.
Chain looks like this mic dujour> 1176> LA2A> pre dujour usually a Neveish thing or a Burl or a ViPre> PTHD. I can fill the track nicely with no overs and need very little on the track @ mix.
I have everything in my room on a quality patch bay and this is the tool needed for this.
I compress bass on the way in. I have a couple of channel strips I like for this. When I am doing a full tilt bass capture that involves an amp I will compress the mic signal from the amp and DI without compression IF and only if the bass output is a balanced signal.....ie: all strings sound at relative volume. If it doesn't the I will compress the DI through something like a DBX that has expansion on the end of its signal. A bass comp should be fast on it's input and have the ability to set the release as well as the output.
Guitars I will crush the crap out of if it's a heavy track. Otherwise nothing. Although, an 1176 with buttons off infront of the preamp for a guitar feed can be quite magical.
Is this "old school" ?? Yep. And it works. Every time.
Yes that is true. Or rather it can be true. I am always trying for a good level in the track that will make anything added @ mix work as it should. I don't want to spend time getting a sound and then tracking only to have to fix little widgits here and there. I will almost always use a fast compressor on a mic in front of an amp/speaker. I just want to catch the big transientsThe funny thing about recording bass amps is the fact that the mic itself becomes a "limiting compressor" along with the amp itself. I find I compress DI bass most of the time and amped bass rarely.![]()
I'm not sure it's the mic, Bass amps tend to compress though.The funny thing about recording bass amps is the fact that the mic itself becomes a "limiting compressor" along with the amp itself. I find I compress DI bass most of the time and amped bass rarely.![]()
