S
		Svemir
Member
Hi there,
I am still confused about some gain staging matters.
Seems there is too much hype about gain staging, people freaking out about it, when hearing mixed tracks here on the forum claiming the guitars are too hot!
First of all what do you mean by "hot"?
Is a metal super distorted guitar hot? of course it is by definition! it's super distorted!
Just to make you understand my doubt I have properly gain staged my guitar track as per manual, then I added a guitar amp plugin where you can choose different amps.
I have chosen an amp I like, despite the sound is great is lacking some distortion even if the amp gain is at maximum, this because when I did gain staging at the beginning I had to decrease the gain knob to stay between -18 and -6db.
So I decided to increase the gain on the track to increase distortion, and in order not to clip I decreased the volume fader, is this OK?
Usually everyone says that you should gain stage, then if it's clipping with plugins you should decrease the plugin output or gain, but that would change the sound making it less distorted, so I just low the volume fader.
My question is, instead of lowering the gain knob on the track in order not to clip, is ok if I low down the volume fader instead?
In the following video, he says it's just fine and ppl are just making too many issues with gain staging.
