I am far from any expert in digital matters but find a proper one and they will tell you that the "resolution" of digital recording is 6dB per bit and that decides the noise floor...Nothing else. The sampling rate determines the highest frequency you can record which will be a little under half said rate.
That is all. I shall leave you to it.
Your thinking this thing all wrong....  I already know 24 bit is max bit depth etc....  That is full digital spectrum, but  your taking this whole resolution thing = highest possible recording freq attitude is a little closed minded.  It is not at all as that simple as it is.  Think of it like dpi on a monitor.  They are both 10 bit HDR monitor so you get the full color range, but the 4k monitor is going to be much much more detailed of an image than a 1080p just like a 768khz 24bit audio recording will have much much more clarity than a 44.1khz.  It is not just highest freq possible.  Think of your speakers, and ear and brain as a low pass filter.  Now the higher resolution audio is going to sound much better through that low pass filter of your brain.
TalismanRich
I haven't bought the RME ad Pro2.  I just don't want to spend 1,500 dollars on something and have it not be able to pick up my bass or VCO's.
Bluetooth 5.0 has aptX.  I heard that is lossless.   Anyway i listen to a lot of vinyl and have amps hardwired so I can play anything.  I'm trying to get enough good music together to press a vinyl perhaps.  I'll probably go with a half inch tape machine anyway becasue it is cheaper than the 1,500 dollars.
***  and as far as bass goes.  i want to be feeling it on my chest.
That infra sound video posted.  I couldn't hear anything bass wise going on outside the normal kick?  They didn't seem to line up.  Is there anything i am missing or do i need to send a wire to the amp as opposed to streaming it wirelessly.
testprojectmain out.flac - Google Drive
Compare the 96khz Vorbis Audio to the 384khz flac.  See if you can output 384khz audio.  I've never heard nothing that clear from a CD.  Just saying.  Try using a HDMI video card or Display port digital audio out from a monitor.  Tell me if it makes yourt amp crackle.  It sounds great through a wire to a H20 Jacket Bluetooth speaker, but crackles the speakers a little.  I have to hook it up to the tubes for optimal playback.
Do you guys have VCO's?  That synth is more bottom heavy than that.  It is almost indistinguishable the right hand stuff, but is ever so slightly thicker.
I added the bass running through this little pre amp before mobo
			Using a 786kHz sample rate for more clarity in an audio recording is like using a turbofan engine from an airliner on your car for more performance. It's just about the most useless and counterproductive thing you can do.
People who design this gear aren't idiots. They don't filter out low frequencies to the point that it impacts the ability of the system to capture bass.
But you seem to think you're the expert, so I'll just let you carry on with whatever it is you're trying to do. Good luck.
I don't know why you are taking this hostile approach and claim that I claim to be an expert.  I am merely asking a question here becasue what i currently have is not producing enough bass.  I also noticed that alot of a/d converters have built in HPF's, so I don't want to buy something and be having the same problem.  I also thought the idea of owning a 768khz a/d converter would be cool, but I need it to bump if you know what i mean.
