L
lastrenman
4. Inside the closet, right side wall is cement and left side is wood.
Have you listened to recordings done in rooms with foam panels?Thanks again for your help. I put up safe n sound only to then find out that it uses formaldehyde binders. People on different message board service were arguing whether it was safe or not. I don’t want to take the risk. I’m getting some foam panels but didn’t know if there is a difference between Auralex soundproofing and a no-name brand for half the price. Thoughts?
I assumed most professional studios used them in combination with other diffusers.
Hmm. Not sure what you are looking at. Male voice fundamental frequencies top out below 1kHz and can go below 100Hz, so you'd only be hearning harmonics in that frequency range.Keep in mind that the frequency range will be limited to the male voice. The foam won't trap typical male vocal frequency range? Approx 800-2500?
