Massive Master
www.massivemastering.com
Think of it like this -- 44.1kHz exceeds the limitations (22050Hz) of basically everything in the chain (up to and including human hearing). 24-bit word allows for a dynamic range (>120dB) that exceeds the limitations of everything in the chain (and introduces no dither noise).
Except for a final delivery format, it makes no sense to go lower. But as either of those parameters exceed the typical limitations of everything else down the line, there's generally not much advantage to going higher.
Personally, I'm much more interested in the quality of the source and the quality of the gear. My AD at 44.1kHz sounds better than most I've tried at (whatever). A good source being captured by a quality chain in a quality space is going to make a far bigger impact than anything else.
Have you ever heard a really good sounding MP3...? You're basically hearing a *lossy* version of a 32kHz recording (usually, with a terrible and sloppy cutoff at the 16k limit). Yet, they can still sound totally decent and listenable - depending on the source recording.
) that half the signal/dots/bit (1 A) do not make the line (1 B) as it actually seemed to be (2 B) when drawn with more information (2 A). And a more real original line (2) gives correcter effects as result.
