G
GotHemi
The Mackie Big Knob has a built-in phono preamp that I would like to use with my turntable, along with 2x stereo source inputs & DAW Input & Output.
I haven't purchased the Mackie Big Knob yet, so I'm asking if it can do what I want beforehand.
The Babyface Pro has 4x analog inputs (2x xlr - 2x trs) & 4x analog outputs (2x xlr - 2x headphones), along with adat in.
The Mackie Big Knob manual mentions going out from the Big Knob & into the Babyface. Then, out from the Babyface & into the Big Knob.
My JBL monitors would be plugged into the Big Knob using Monitor A inputs, coming from main XLR outputs 1 & 2 on the Babyface Pro.
I would have a Bass Station mono synth plugged into analog input #3 of the Babyface Pro.
The sources I would like to have connected to the Big Knob are the turntable (connected to the phono preamp) & a JP-8000 stereo synth (connected to Source A)
Since audio needs to feed the Big Knob from the Babyface, then from the Big Knob back into the Babyface, would it cause a feedback loop everytime I wanted to route & record audio from the turntable or JP8000 into the computer?
What I would like to do is: Have a drum break on loop inside FL Studio 12, then record a sample off the turntable into FL Studio and have it play on loop with the drums. Finally, I'd like to play a pad sound from the JP-8000 in real time with the drums & sample as a backing & finally record the JP-8000 audio onto a separate track. So I'd end up with 3 separate tracks inside FL Studio 12 (the original drum loop, recorded vinyl sample loop & a JP 8000 pad loop). Rinse & repeat until song is finished, without having feedback loop problems.
I didn't want to buy something like a Behringer ADA 8200 unless I absolutely have to, because it would be just something else extra to buy, plug in & run cables to & from.
Thanks for any help!
