C
Coquet-Shack
Member
there is no control with my stock "mastering suite" limiter plug other than on, or, off. It can get confusing
rofl
So you're saying you're lazy.Limiters with threshold/makeup gain type controls can be made to work but it can take some futzing around.
So you're saying you're lazy.![]()
Can you recommend a limiter that works on the drum bus? Freeware would be nice.
Thanks. I'm 64 bit. I'll give it a try. Always interesting to hear what another compressor brings to the table. But for current purposes, what I'm really looking for is a transparent limiter that I can throw across the drum bus to tame the occasional spike. I want to set the threshold high so that it is only kicking in on those spikes, and then I want it to stop them dead. Otherwise, I don't want to hear it. For a more textured compression that does that glue thing you mention, ReaComp run in a parallel configuration sounds good to me.
If you know what you want and have a clue what you're doing, it won't take an hour to dial in and save a preset. After that, loading the preset takes about as long as instantiating some other limiter that doesn't even give you the option of changing those parameters.That, and charging clients for an hour of work that could be done in seconds with the right tool doesn't go over too well.
It's really more like having a car with processor controlled ignition timing instead of one with a lever on the steering column. Sure, people used to drive their '29 Chevys all the time using the manual spark advance, but vacuum or centrifugal control is way better, and digital ignition control is even better than that.
...the manual spark advance, but vacuum or centrifugal control is way better, and digital ignition control is even better than that.
who did what now?
Well, there's the automated braking system that might toss you into the lake
That's because the idea of a singular favourite doesn't really make much sense.
why's that?
fa·vor·ite
ˈfāv(ə)rət/
adjective
adjective: favourite; adjective: favorite
1.preferred before all others of the same kind.
I'm using the Reaper plugins in Sony Vegas.
One reason multiple plugins are mentioned is that you pretty much need at least one eq, one compressor, and one reverb. For mastering you also need at least one good mastering limiter. That's the minimum to get things done.
...and of all those, which do you enjoy using the most...![]()
